replacing wheel studs wat size nuts and also
    well im replacing my brothers wheel studs in the driver front and the driver rear of a 94 accord ex with rear disc and im wondering
    what do i need to do?
    can i just take the wheel hub off with bearing removing the 4 bolts behind it?
    can someone please help me with this asap thanks
    and also what size is the front axle hub nut and also the rear axle hub nut thing?
    this is for a 94 accord ex thanks
    MY FOR SALE THREAD
    My Recent CB
    My Old CBs
    1991 Honda Accord EX - MY NEW ONE
    1991 Honda Accord LX - Impounded and GONE
    1993 Honda Accord EX H22 - SOLD
    BTW IM NOT TURBO.. I WAS GOING TO GO TURBO WITH MY FIRST CB.. BUT IT GOT IMPOUNDED
    I am pretty sure you can reinstall OEM length studs from behind without having to remove the hubs. I know you have to remove the hubs for longer studs and from what I understand this often if not always damages the bearings.....not sure why as I have never done this but its what 2 friends have told me is at least true for Integras
    use a lug nut to pull the new stud in tight, someone posted a write up on installing longer studs and said you have to use an impact gun to get them on all the way but I dont know about that??
    Bought from Darkcloud
    http://wheelflip.com/r/DrAkE
      I'm not sure on the 94s, but on our cars the lug is M12x1.5. Unless you are using APR or Blackworks extended studs, PLEASE PLEASE PLEASE go to Honda and get OEM studs and nuts.
      I had replacement studs put in before and they just arent the same quality. Nothing is worse than changing a tire on a busy section of the 401 and night trying to get a nut off a stripped thread. (No, they were not improperly installed either.)
        They should just be able to be pressed out on a press, and pressed back in. It's pretty simple.
        Yes my name is Dang, Don't use in vain
        1992 Honda Accord EX (Coupe/Bordeaux/Auto)
        1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
        2008 Honda Accord EXL (Coupe/SanMarino/6spd)
