control arms
    control arms
    i need to buy new upper and lower control arms on both sides can anone tell me some good low priced arms? need help asap
    ...y are they bent?
    TAS auto
    Retro!
    Hater
      no im just switching everything cause i got the car and i just got it out on the streets and all the studs on the right front wheel broke off so im doing new suspenstion and brakes
        If you still have factory arms your best option is to order a set of POLY bushings from energy suspension or a similar vendor. Most of the aftermarket bushings that come on the arms are complete BULLSHIT. Right after the bushing fails then the ball joints are soon to follow. Honda is the best, then I would say either Moog or TAS auto shit. Warning moog is expensive though. Any other cheap arm is str8 bullshit. On the other hand the bushings in the lower control arm seem to last a decent while even on some cheap aftermarket arms.
        FOR SALE on cb7tuner only for now. Want it in the right hands
        Pm meX
        I do swaps in NYC/LI area: Hit me up for a quote.
        MY WHIP
        H22A Swap
        I'm 'THE STIG'
          Advance auto has moog arms for a good price, go that route.
          wat?
            i nee a lower ball joint too so im guessing most of the bushings are bad and i herd poly bushings are hard as hell to install
              Honda OEM ball joints, Poly are easy as hell to install, getting the old ones out... that's a different story haha.
              wat?
                haha really? i will look into the bushings and the ball joint ill buy next time i get paid should i change both sides cause i only checked the passanger side
                  I bought some Autozone ones....got em for 104 bucks OTD for both. So far they're holding up fine. Plus they've got a lifetime warranty...so if the boot tears and grease comes out, I get new ones.
                  bought Honda OEMs for the lowers since they were only 21 bucks a pop
