*cliff notes at bottom*
so first off, i should say my car has been in an accident. since i bought it a year ago, it has been pulling to the left or right, sometimes hard, sometimes barely noticeable. i got a new set of rims and tires and after a proper alignment and wheel balancing, the drifting stopped. a few days after that alignment, it started back up again.
the guy at town fair tire who performed the alignment said because of the accident, it would be impossible to properly realign my car. i then mentioned i was planning on getting a new suspension and he said that would solve my problem after i got it and a proper camber kit.
now i brought this information to my dad and i told him how much a new suspensions setup would cost. i told him about $600-$700 for everything. i'm pretty sure i'm within a reasonable budget. now what i want to know is what are the best springs/shocks/ anything i need to make my suspension right again.
now, i did A LOT of searching and spent a couple of hours reading over every sticky but most of the posts have to do with slamming a car or just don't fit my needs.
i want the drop to be about an inch to an inch and a half. no lower than 2 inches because of the roads around here. i've been looking around and taking advice and found some stuff i might like. from what i can read, eibach is a great brand with some parts i'm looking for, especially the springs. as for the shocks, the KYBs look very promising with a lot of good reviews. can i use these in combination with each other to achieve my desired drop? i don't think i'm interested in a coil over set up.
http://cgi.ebay.com/ebaymotors/KYB-S...item2c58e322e1
or
these springs
http://www.innerauto.com/store/detai...3D%3D&x=21&y=8
with
front- http://cgi.ebay.com/ebaymotors/KYB-4...item2a09c9a810
rear- http://cgi.ebay.com/ebaymotors/KYB-7...item5add96d6da
is there anything in addition to these items i may need to buy? such as camber kits and bushings etc. i want this suspension job to be done right with some quality parts so any advice and links are greatly appreciated. i'm scavenging ebay as you read this but i want to be sure i'm pointed in the right direction.
spc kit: http://cgi.ebay.com/ebaymotors/KYB-7...item5add96d6da
energy suspension kit: http://cgi.ebay.com/ebaymotors/Energ...item45f70d934c
i'm also interested in strut bars or possibly sway bars depending on how expensive and complicated they may be.
*CLIFF NOTES*
budget: $600-$700
want: a drop of about 1 inch to an inch and a half, no more than 2 inches, ride comfort to be mildly better than performance handling
need: to replace most if not all suspension components.
thanks in advance
or
these springs
with
*CLIFF NOTES*
budget: $600-$700
thanks in advance
