Rear Camber washer question?
    I've seen several people ask about this and I havent found an answer myself either. How and where do you install the washer on the rear to correct the camber? A picture is worth a thousand words! How many should be put on? Any help would be great
    Jack up the car and u will see a bar bolted to the chassis by 2 bolts. (look above the tire in the fender well) Loosen the 2 bolt and put the washers in between the chassis and the bar. If u need more than 2 washers to straighten the camber, get longer bolts.
    PURCHASED NOVEMBER 1991. THAT'S RIGHT, I'M THE ONE AND ONLY OWNER. BEAT THAT!
      Don't forget to get an alignment after you do this cause camber affects toe!
        Thanks for the answer, seems easy enough.
