rack and pinion bolts fell off
    how the fcuk does that happen!?!?!
    I was at LAX today and heard a loud clunk and I got freaked out..I was driving and noticed my steering was hard as fuck..next thing you know I can barely turn the wheel..I get home and my first though was broken belt..to my surprise it was still in tact..next thought was broken line..once again wrong..lifted the car up and did the tie rod test and both sides moved like crazy amounts..I got under the car and notcied something was wrong because ALL MY FUCKING BOLTS WERE MISSING!!!!
    the two actual bolts that hold the rack in and the brackets were hanging on by one bolt each..
    someone please explain this to me..the rack and pinion were just recently changed and bolts were put on right..soooo?????
    WTF!
    Rush
    Originally posted by Darkcloud
    Bought 3 things, 1 that goes boom,1 that shades and 1 to go fasrer
    Originally posted by bmxicansd
    so you got a boombox, sunglasses and rosettta stone?
    The bolts weren't tightened properly or the wrong bolts were used.
    My 5.7 LS1 Holden Ute
      WTF!
      use lockt tight always
        You don't need loctite, just need to torque them properly.
          didnt get a chnace to use anything since we were in a rush, bu t the abotls were on there...im gona get som a the yard tommoro so its al good
          Rush
            i have it to were the nut thats in the frame that the rack bolts to the nut for one of them is no longer welded on the inside of the sub frame ??
            what to do haha
              I check all the bolts under the car regularly, they all come loose over time.
              what to do haha
              you can either change the subframe or have yours repaired, either way it is a pita
              1990 accord Honda-Challenge, H22 powered
              newer race video,older race videos
              1991 accord parked, parts and back up shell
              1993 accord acquired 6-11-16
