Hows this suspension set up sound..
    I am going to redo my suspenstion..I'm thinking of going with KYB AGX's with H&R race springs.. it's a 2.25/2.5 inch drop. do you think that will be enuff drop for 17's??
    or will i have to go lower?
    cb7's stand high as hell
    that should be plenty... good choice in parts tho..
    ppi
    DD: 1998 Honda Civic EX Coupe
    PC: *searching*
      AGX's will blow on that low of a drop. You know that he AGX's warrenty is void if you lower the car moer than 1.5 inches right?
      Tein SS
        That is correct!! They wont last as long that low, go with tokiko's bilsteins or konis. Good Luck!
        mmmmmmmmmmmmmm....... DOHC
          i suggest koni yellows. thats what i have and the ride is great. i have it set at the softest setting and it almost rides like stock. only downfall is they are expensive.
          a 2.25/2.5 drop will be more than enough
