Pop noise
    Pop noise
    Sometimes when Im turning right I hear a "POP/CLUNK" noise but its only one pop not several so I dont think its the CV. I know my rotors are bad so im hoping by my neglecting to replace them (everything is being fixed next week) didnt cause further damage (the extreme shake while applying the brakes). I feel it more in the steering wheel if that helps.
    A nice car is a dime a dozen. It's the amount of respect you give your car that makes it a GREAT car...and it shows.
    Ball joints or tie rod ends.
      Ill bet tie rods... Mine did the same thing... Prolly a good idea to ahve them changed anyways.
      I reccomend you get Moog, you can order them through advance auto parts I thin oriely stocks them...
      My System
      http://www.cb7tuner.com/vbb/showthread.php?t=165155
        also check swaybar endlinks.
        Retro!
        Hater
          Will do. Thats what I was leaning toward...The tie rod ends or ball joints. Im having all sorts of problems with it really. The brake light comes up some times when I apply the brakes moderately and then the ABS light follows. Judging by similar problems I have seen in the past I'll assume its the rears (considering the E-BRAKE doesnt work, hardly at all anymore). In the shop tomorrow.
            dude ur such a noob.
            check ur brake fluid levels. Both lights come on when the brake fluid is low. Also the brake fluid gets low when your pads are worn.
            Retro!
            Hater
              The fluid was the first thing i checked
