How do u separate these 2 pieces in the rear?!?!? im in the middle of my disk conversion and cant get the upper arm off the knuckle arm of the old drums
How The Heck!?!?
Originally posted by Shadow1 View Postthere is a nut on it but its kinda like the front upper and lower ball joints. you have to hammer them out. i had this same problem with my rear disc swap. i just used the UCA from the other car and put it all on together. a WHOLE lot more simple.
Behind Every Successful Person...Lies a Pack Of Haters!
-1992 Accord EX H22 234whp 185wtq
-1993 Accord EX SOLD
-1995 Accord EX Wagon Daily Driver
-2012 GMC Canyon V8 4x4
Originally posted by 1qukcb7 View Postused that tool and it worked!! thanks< but now i cant get the rear rotor off.... are those 2 screws supose to lossen it? or should it just slide off?!?!
Originally posted by quaidum View Postif you are replacing the part what would the boot matter there is a new one on the new control arm that is being put on
Originally posted by Uncle WilleyWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
Originally posted by JaberCB7 View Posttrue but what if your doing something else like chaging axels and you have to remove lower ball joint? i still havent found a good way to pop em out without hurting the boot
or you can remove the nut then hit the lower control arm with a hammer around the balljoint it takes a few good wackes with a 2.5 lb mini sledge
