gangsta lean
    gangsta lean
    so im at work and i went out 4 a smoke break and as im smoking and admiring my car... I notice my car has this lean 2 it. I grab my phone and use it as a measuring device... So im checking the clearance on the 4 corners and find that my front passanger side is sitting about 2 inches higher than the rest of the car. Any ideas of what the issue is?
    Were you parked on perfectly level ground?
    If you were parked on level ground, you need a really fat chick to ride in the pass seat for the next few weeks.
      ground aint perfectly flat but its close enough that it wont justify a gap that big
        ok so i jus went on another break and measured the clearance from the top of my rim 2 the bottom of the fender and on the 3 good corners i got 7 1/8 and on the bad corner i got 8 1/4. Where im sitting, the ground jus barely slants 2 the passanger side which would make it sit lower than the driver side and this is all ass backwards
          correction... It leans 2 the driverside
