My car has a little front end shake when I accelerate. The guy at the alignment shop said that the cause is because the axle is bent at an extreme angle since the car is lowered. Now, I've seen accords way lower than mine, and they have no issues. So I'm assuming that there is another issue with the front end, correct? Thanks.
Lowered accord axle question
Originally posted by fatboy1185 View PostMy car has a little front end shake when I accelerate. The guy at the alignment shop said that the cause is because the axle is bent at an extreme angle since the car is lowered. Now, I've seen accords way lower than mine, and they have no issues. So I'm assuming that there is another issue with the front end, correct? Thanks.Header Whorage and Official Part out sale.
Official Garage Sale Thread
http://jdmconcepts.com/ Head porting specialist..
my axle was viberating under acceleration just before it broke-1992 Accord EX H22 234whp 185wtq
-1993 Accord EX SOLD
-1995 Accord EX Wagon Daily Driver
-2012 GMC Canyon V8 4x4
bad axle can be the cause but that doesnt mean it was from the car being lowered. i was dumped out and my axle was bad cause some vibration along with bad mounts. since then i have replaced mounts (esp) and both axles with brand new ones... no issues.Members Ride sold...
So I replaced the axle, issue went away for 1 day. Now it is starting to vibrate again on acceleration, but not nearly as bad. As an experiment, i lowered the car even more. Vibration go worse. I have no camber kit. Could my wheels being cambered at an angle cause the axle to bind or anything?
Originally posted by gloryaccordy View PostSomething is telling me to tell you to check your mounts. I don't think the issue is axle related
Originally posted by fatboy1185 View PostWell why would the issue go away after an axle change?
On another note, just because your "new" axle still vibrates does not mean that the axle isn't the problem. I've had alot, I mean ALOT, of the cheapo remans and "new (whatever)" axles from parts store be bad right out of the box. Just saying not to write of the axle just yet.My Member's Ride Thread
I'm going tomorrow to get a toe job done. Last time I went, he told me it was an axle issue, and said raise the car, then come back for an alignment. But there are lots of slammed cars with no vibration issues. So I'll just tell him I want the toe fixed, then if it still vibrates, start checking other things.
