Blown shocks?
    Blown shocks?
    So I finally got the cb7 out after replacing wheel bearings and an axles. Now i noticed when my back seats were out the rear driver side shock sounds like its basically rattling around. Im talking about the top piece, along witht that theres pieces of rubber all around it like its tearing apart the little bushing thats sitting on top. Is it a blown shock or do i have some other problem that im not looking at?
    My New Ride
    http://www.cb7tuner.com/vbb/showthread.php?t=82630
    if its rattling it can be the strut mount bushings.
    Retro!
    Hater
      bushings or collar slipped.
      [COLOR="Magenta"]
        So what do you guys suggest i do to fix it? Tighten down the mounting bolts?
        My New Ride
          Have a look under there to see what the problem is. If it's a bushing you should be able to see that it's failed. If so, replace it.
          Unless the problem is that you simply haven't tightened down the top hat or the mounting nuts enough or they've come loose. In which case tighten them up.
          Members Ride Thread
            I didnt see my upper bushings, they looked fine. but they rattled when you hit small bumps. so i replaced them and the sound went away.
            Retro!
            Hater
              I think its your strut is failing. Check your bumpstop and springs & check any torn.
