Aight, some of u know about the Energy Suspension ordeal & how they work great for 1st like 6 months & then slop develops. I believe this occurs because polyurethane in itself is so stiff & when lube wears out or is not applied, wears itself out against the metal. Polygraphite is poly, but has graphite integrated into the material, lubricating itself in flexing, so I believe it should last longer & still give improved handling.
Well, I just found out about PST (performance suspension technology), which primarily deal w/muscle car, but like many has aimed products toward sports compact market.
www.P-S-T.com FREE UPS SHIPPING 48 states (exc. hawaii, alaska)
They sell polygraphite front end kits for 90-97 Accords $239
kit includes (some or all apply..call or check site for sure):
2 upper & lower ball jts w/poly boots
2 outer tie rod ends w/poly boots
2 or 4 poly lower control arm bushings
4 upper inner control arm bushings
2 strut rod bushings
2 stabilizer end-links
2 sway bar bushings (inners)
PST also sells other things for CB7's like poly coil spring isolators $15/front set only, KYB AGX's $389 set of 4
