Replacing bushings on front end
    I have searched on this site and a couple of other ones along with using google and can't seem to find a how-to on replacing the bushings on the front end. It's and Energy Suspension kit. Anyone know where this might be?
    I though cp mike made a thread about this...brb...searching
    *back...guess not...hmm. Found this though
    http://www.cb7tuner.com/vbb/showthread.php?t=8980
    not sure it that'll help you...kinda gives you an idea. Some I think will press right out...some...even with a press will not.
    I know the latest edition of project car went over some stuff briefly.
    ____
      If you can, take the arms out and take them to a mechanic that has a press to get them pressed out.
      I used a butane torch to burn out the rubber then cut out the outer collars with a hack saw. Long, annoying process. I would do the above option if I was doing it agian. Or just buy a press. Putting the new ES bushing in is easy because there is no outer collar.
      Members Ride Thread
        I bought extra arms from other members and had the bushings pressed out off the car to make the install easier. Only the Lower Control Arm and Anchor bolts (from the Upper control arm) need to be pressed.
          Thanks for the help guys. I've never had to do it before and a friend of mine on this site asked me so I was trying to get as much info as i could on it to help him out.
            If you don't have the tools you will need to pay someone to do it. It's best to go to a trusted mechanic. It wont be cheap and often they charge based on their hourly rates
            http://www.cardomain.com/ride/2620526 190E Mercedes Benz
            http://www.cardomain.com/ride/3065882 Accord Under major Repairs
