I have both Illuminas and AGXs. The AGXs are far superior than the Illuminas.
CB7 Lowering Spring, Full Coilover, and Damper compilation
This is a sticky topic.
Originally posted by djcaz_aom View PostI have both Illuminas and AGXs. The AGXs are far superior than the Illuminas.
Originally posted by lordojaim with you on that one bro! aint nothing beat free food and drinks any day of the week, even if its at a funeral
Awesome, we have an argument going! Based of those mustang and civic graphs, I'm inclined to go with the AGX. Other than the fact that it is a drop killer, it seems to have better curves.
Keep in mind, how well a shock performs has nothing to do with whether or not it "kills" drop. Also, just because the AGX might have better looking curves does not mean that it lasts longer...it seems to be the consensus on this site that the Illumina will outlast the AGX.
However, you can see there is a large variation between the mustang and civic graphs in both crosstalk and adjustment range....so the variation for the CB7 could be just as large. If only we could get charts for the CB7 application...Last edited by mndude07; 02-10-2010, 05:30 PM.There are no black and white suspension answers!!!!!!!!!!!
I'm running the eibach pro kit and agx struts/shocks. I think they're great. The drop is only MAYBE 1.5" probably more like 1.3" but according to the OP the springs are pretty stiff. I never get that slammed car "bounce" like some complain about on other suspension. I hear about lowering the car with AGXs causing them to blow - mine have around 50k on them and have been on full hardness the whole time (except for a week at full soft) and they haven't ever leaked or anything. I can take corners as fast as I want and never experience understeer or traction loss. My only concern is that I wish the drop was about 1.5-1.7".
Originally posted by mj213 View PostI'm running the eibach pro kit and agx struts/shocks. I think they're great. The drop is only MAYBE 1.5" probably more like 1.3" but according to the OP the springs are pretty stiff. I never get that slammed car "bounce" like some complain about on other suspension. I hear about lowering the car with AGXs causing them to blow - mine have around 50k on them and have been on full hardness the whole time (except for a week at full soft) and they haven't ever leaked or anything. I can take corners as fast as I want and never experience understeer or traction loss. My only concern is that I wish the drop was about 1.5-1.7".There are no black and white suspension answers!!!!!!!!!!!
Originally posted by mndude07 View PostAwesome, we have an argument going! Based of those mustang and civic graphs, I'm inclined to go with the AGX. Other than the fact that it is a drop killer, it seems to have better curves.
I've found generally that at my car's height the Illuminas' low speed damping isn't enough. Mid range bump/rebound is pretty good, but high speed bump again is too weak. They have handled about 5,000 miles of some pretty brutal roads though at a very low height. AGXs would have been long gone.
Really though I should have ponied up the extra $150 for the Konis. I actually ordered them, but there was an issue with the shipping address so I cancelled the order and got these Illuminas. In retrospect that was a pretty boneheaded move as I hear Skunk2 springs with Konis is the ultimate setup (better than Races or Sports). Oh well
Originally posted by gloryaccordy View PostLooking at the graph, my observations kind of match up; however, I had Konis with Neuspeed Sports (300/200) vs now where I have Illuminas with custom rates (440/300, basically Neuspeed Races). The best part of the Konis by far were their excellent low speed damping abilities. There is a series of bumps on the way to my parents place that really tests a suspension's range, and with the Konis it was like those bumps weren't even there. With this setup now I get some rocking and a little bottoming out.
Really though I should have ponied up the extra $150 for the Konis. I actually ordered them, but there was an issue with the shipping address so I cancelled the order and got these Illuminas. In retrospect that was a pretty boneheaded move as I hear Skunk2 springs with Konis is the ultimate setup (better than Races or Sports). Oh wellThere are no black and white suspension answers!!!!!!!!!!!
Originally posted by 4CYLPOWER92 View PostI see you don't have F/F spring rates listed. According to a link on their website, both the type 1's and 2's are listed at 12 front, and 6 rear. So that comes to 672 and 336 when multiplying by 56 as per the conversion.There are no black and white suspension answers!!!!!!!!!!!
Originally posted by mndude07 View PostCool, thanks. I'll add those rates. I couldn't find them when I looked awhile back. They must have just put them on their site recently.
Originally posted by mndude07 View PostYeah you should've waited for the Koni's for sure lol. Where did you hear Skunk2's were better? Are you talking about the coilover sleeves or the actual springs? Their springs don't drop as low as the Neuspeed springs(don't forget about the effects of lowering CG), and I haven't been able to get any info about the actual spring rate. Are they stiffer than the 485F, 300R that the neuspeed race are?
I'm too lazy to search but if you look for threads started by H23Accord in here you will find the reviews. Maybe I will post them up later. They were good threads.
I got rebound and compression numbers for the Bilstein HD's! Especially make sure to compare those numbers to those of the Koni
STR.t. Notice the Koni is stiffer in the front, but the Bilstein has around 3x the compression in the rear.There are no black and white suspension answers!!!!!!!!!!!
Originally posted by Gmoney707 View Posthow come people ddont drop their car the same from the front and backk?
When the front is lowered 2.2"-2.25" and the rear is lowered 2", there will be about the same amount of gap between the tire and fender all around.
If you lower is 2" all the way around, you'll have more gap in the front than in the rear.
