Seeking opinions on cheap, adjustable shocks.
    I'm looking to buy a set of eibach sportline springs which give a 1.8" drop. Originally I considered getting KYB AGX's, but they won't warranty any drop past 1.5", so I need to reconsider. I assume it would be better to get adjustable shocks, so I can tweak the ride some. So I was wondering what would be a good shock comparable to the agx's in terms of price that will work for a 1.8" drop. This is the first time I'm modding the suspension so I have no knowledge of what is good/bad or better/worse. Like I said I need a set of value shocks because I don't have money for koni yellows (which I hear are t3h pwn). I appreciate all input.
    i don't think there's a cheaper adjustable shock than the kyb agx. since you don't want to change your spring selection, i guess your options are:
    1. find a set of used koni yellows
    2. say screw a warranty (there are probably plenty of limitations on the warranty anyway) and get the kyb agx's
    3. save up and get brand new koni yellows
    of course if you want to change your spring selection, or get shocks that aren't adjustable your options will widen.
      You can go with the KYB's and prokits and have no problems at all. I am running a 2+ inch drop all around on KYB AGX's and I have had no problems at all.
      Honda-Tech Username: Lostcb7
      The cb7tuner.com OG.
        I'm running the same drop on kyb gr-2's and havent had problems yet.
          Thanks guys thats what I'm going with!
