im so sick of the shimmy
    You can't forget about your tires....
    Mine does that and at last it turn out to be my tires..
      my car does this as well but its once i hit 55 the front end shakes.
        mine shakes when i hit a bump or a hole, and it shakes as if something is loose but i fail to find anything loose, it only shakes when i hit a bump or is slowing down from 70 mph or sum, i dont think its because they arent balanced but i will get that checked
          Rack & pinion.
            shocks, wheel balance, maybe even a bent wheel. Excessive toe out (alignment)
            93 EX Arcadia Coupe, 5spd, f22a6, strut bars, 2"drop, baer brakes, ingalls camber kit, tokicos w/ eibach, K&N, 205s / 16s
              Any time Ive had an issue like that its almost always been a fucked up tire.
              Members Ride Thread - http://www.cb7tuner.com/vbb/showthread.php?t=121452
              Originally posted by slammed4thgen
              dustin, you are a dick!
              officially the lowest ive seen now
                Makes sense, an out of balance tire or one with a busted steel belt would be like having an out of balance washing machine on "spin" cycle bolted onto your axle as you drive down the road.
                  I got an alignment, now i just have to get my wheels balanced
                    got my wheels balanced, and also two new front wheels, but still my front right tire wobbles while driving its like it rides smooth on a smooth road, but if you hit the smallest bump on the right side it goes boobly boom boom boobly boom.....the wheel vibrates horribly but i have jacked the car up several times, nothing is excessively loose
