Acura Cl 3.0 hubs?
    Acura Cl 3.0 hubs?
    just curious but why are we not ale to use the 3.0 hubs? different axle spindles?
    The 98-99 3.0L CL's were HOR just like our CB's
    http://www.acura-cl.com/forums/showt...php?p=10058597
      interesting bc the setup on the car is ROH. i just picked it up 2 days ago. its a 99 cl3.0
        only the 97 hubs are hub over rotor.
        The 98-99 are the ROH.
        The 3.0 hubs are different. I cant remember if its the axle splines or the length of the hub itself.
          its the splines themselves that are different
          Maple50175 - you're annoying =P
            well i have the whole car here and i thought id use them vs paying $300+shipping
              I have the 3.0 hubs. trust me they arent like the 2.3
              so dont get them unless you can find a hub that works with it. cuz the bearing sticks back more then the CB/2.3CL one. also the hub shaft is a tiny bit wider.
              but itll work with the CB axles. I tryed it
              I hear the odyssey hubs/bearing are big too. maybe theyre knuckle will work with the 3.0 hubs/bearings
              93 Accord LX Sedan (sold)
                so wait if you get the 3.0 knuckle it will work? i can get the knuckles off a 3.0 but teh hubs fit and splines are the same?
                  I already tryed the axle into the hubs. it seems to fit just right.
                  try the knuckle
                    Pretty much all honda axles are the same so thats no problem. The problem is when you get to bearings that fit in the knuckle and also can have the hub you want pressed in.
                    wat?
                      try the knuckle
                      oh snap
