I just order a complete set of Megan strut bars, im just wondering where does the lower tie bar go? are there predrilled holes for it? And also, will the front strut bar fit over my f20a swap?
Rear lowet tie bar install?
Yes there is a place under the car where it goes. Actually, if you look at some of the member's ride pages, you will see some good pics of those that have it and that will assist you as to where to bar goes. As far as if it fits over your f20 swap, I don't see why not."This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
FS Part out thread koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
search a bit in here cuase i have a post on it..and a picture.
basically just put up the car so that the rear wheels are elevated.
then there are these 2 bolts that hold it, there is no mistakening the bolts, its right there.
pop one out at a time, place one of the brackets in and put the bolt back in.
you may need some wd40 for the bolts, they are pretty tight.
then do the other side and then tighten the bar.
if u can get the big bolt back in then u going to have to get a rubber hammer and start knocking it so that the whole is aligned again, dont worry its not the end of the world. i did this already. just somtimes it takes banging or it takes pushing the bottom of the tire out a bit so it can go back into place.
make sure u can loosen both bolts first before taking it off...this is so that if u fuk up, u can still ride to a shop.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
usually where the external pole meets the main body of the bar, u can adjust it..it may not look like it but you can.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
they probably sent you the wrong bars, how far can you extend it...go the max amount and put it in...if u still cant then thats the wrong one.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
