Holy screwed over alignment...
    Just got my alignment checked today after a small incident with a curb...
    I about had a heart attack.
    wow u left side got fucked
    get some camber kits, actually b4 u do that take the wheels of and check, the SUSP because, u got mad caster on the right wheel and caster isnt adjustable on the cb from factory
    Just do what PR CB7 said.
      So is the "actual" before the allignment, or after? If that's the after then they made it worse or didn't do anything. Usually they give you the before and the corrected numbers on one report
      My swap thread
      Main relay proplems?--DIY
        Castor is adjustable.
        My swap thread
          I'm too broke at the moment to get the adjustable ball joints I need in order to get everything aligned, so for now, I just had it inspected. The car will be parked until I can get everything in order.
            nope, not on factory components
              Are you positive? I'm pretty sure you can shim the radius rods to change caster.
                well in that case yeah
                but as far as "adjusting", turning nuts, u cant
                  There is a procedure for adjusting castor in the Helms factory manual. I just can't remember what it is. I believe it does involve shimming of some sort.
                  My swap thread
                    yea, you either add or take out shims between the front saddle, and the radius rod... thats how it's adjustable from the factory.
                      your thrust angle is pretty fucked.
                      I <3 G60.
