I replaced my lower control arms and afterwards my ride height was almost an inch higher than it was before. I didnt expect that when I was changing it but I understood why. These are new stronger bushings that allow for less slack when tightened up. So What I didn was tighten up the lower control arm bolt to the chassis up last while the car was still jacked up. My question is, is there a correct point into which the lower control arm must be bolted to the chassis. By the way I just ended up lowering the Tein springs to the lowest point and now its lower that before which is fine.
Lower Control Arm
you want to tighten the arm at ride height, otherwise you are putting additional torsional stress on the bushing.1990 accord Honda-Challenge, H22 powered
newer race video,older race videos
1991 accord parked, parts and back up shell
1993 accord acquired 6-11-16
Originally posted by Karl View Postyou want to tighten the arm at ride height, otherwise you are putting additional torsional stress on the bushing.
that is correct, otherwise the bushing in the arm is acting like a spring. You want the spring to do its own job, and the bushing will last much longer if its not always twisted.1990 accord Honda-Challenge, H22 powered
Originally posted by Karl View Postthat is correct, otherwise the bushing in the arm is acting like a spring. You want the spring to do its own job, and the bushing will last much longer if its not always twisted.
Originally posted by Granite CB7 View Post^Karl def. knows his stuff, "setting" the bushings will def. pay off in the end w/ both longevity and performance. It was really about 1" higher though?
Heres the funny shit now, its lowered itself in a days time after I installed the lower control arms so I dont know if the bushings turned themselves slowly as weight forced up and down on it or what. But to be safe I will reset everything like you guys said I should do it. Thanx, chill
