correct bleeding sequence
    long story short. i need too bleed my brakes now if possible.
    what is the correct brake bleeding sequence? its a 93 ex if that matters.
    i cant find my book. worst case, ill just get one tomorrow, but if i can get an answer now thats save time tomorrow.....got a huge list to do tomorrow.
    Start furtherest from the Master Cylinder and work towards it. I.E. RR then LR then RF then LF.
    My Member's Ride Thread
      i know youre suspose too start the furthest away from the m.c., but are you sure thats the correct sequence?
        What was the point of starting 2 threads with the same question? One in the beginning section which you got your answer to and this section which you have more than enough postings to post in?
          i posted this first, then thought id get a quicker response in the other forum without realization i cant delete threads on this site. sorry bout that.
            Rr, Lf, Lr, Rf
            member's ride thread
            91 Accord SE 176k
              Update!!
              UPDATE!!!
              heres the deal.
              i swapped my car from ABS too NON-ABS today
              is the bleeding sequence still "rr lf lr rf"?
              or does it change since i add a prop valve, and changed the hardlines out?
              essentialy its an LX with rear disc swap now........the bleeding sequence still the same as above?
                Nice, another ABS removal, how'd it go? And your sequence will still be the same, furthest to the closest.
                  it was such a pain in the ass, i feel like punching a baby. everyone tells me "furthest too closest" BUT no one seems too know the correct sequence. i get different answers. our CB's are designed differently (brake wise) than the other hondas. is the correct sequence the same as previously stated? i appreciate the quick response though.
                    The correct bleeding sequence is :
                    1.-Driver Rear
                    2.-Passenger Front
                    3.-Passenger Rear
                    4.-Driver Front
                    And it doesnt matter if its DX , LX, EX or SE.
                      Why don't you take it somewere and have it done and stop waisting everyones time?
                      Take that freek show to the park, maybe the squirrels will care.
                        thats a great question.
