lowered but seriously BANG/ no suspention travel :(
    Okay So on my 02 civic I have Tokico Blues and Progress Springs. Progress rear sway bar.
    Now when I drive and hit the slightest bump it's more like a BANG. When I look at my suspention It looks like I have 2 inches of travel when the car is on the ground. I have cut the bumpstop as much as I can and this is seriously getting annoying. When I'm turning hard and there is a bump or a small hole on the ground I almost loose control..
    It's like the shock is bashing into the frame. I never had this problem with my accord.
    How can I fix this? ugh Makes me wanna go out and buy the Tein true coilovers ughh
    help me someone!
    help me someone!
    2" of travel is not enough travel for the Tokico Blue shocks; these dampers are meant to be used with OEM springs if not very mild springs. Due to their low dampening curve, they need a relatively long shock travel to perform properly. They can only handle low spring rates.
    Ideally, you need some seriously strong dampers to handle a 2" travel. Think Koni Yellows or Skunk 2.
    DEVOTE
    FS: Lokuputha's Stuff
      This sucks. Wish I was told this before getting all this crap. I guess I will suffer until I save up 900 to get the teins ughh
      unless someone else has an output?
        Did you get the suspension installed at a shop?
        How low are these springs anyways? On the website they say 1.8" front and 2.0" rear? That doesn't seem very low at all, which means you should have a lot more suspension travel. Does it have something to do with the suspension design?
        If you picked up the Progress springs that are used with their coilover systems, then yeah, you need a stronger and shorter damper. Probably easier to source a Progress Damper in that case.
        drop by a shop so they could have a look at it. Or post some pictures of the actual suspension installed on the car. We'll be able to see what is going on.
        btw, your car doesn't seem very low...
        these are the coilovers I am talking about.
        DEVOTE
          It is the design. 02-05 Civics and the RSX has the worst suspension design I have ever seen, as far as Hondas go. They are designed to be anti-lowering.
          Gary A.K.A. Carter
          [sig killed by photobucket]
            With that little suspension travel increasing damper bump stiffness will help, but I suspect the springs themslelves will need to be stiffer to prevent bottoming out.
            If you fit stiffer springs then you'll need to increase damper rates to suit the stiffer springs, but I suspect fitting stiffer dampers on their own may not be enough.
            Regards from Oz,
            John.
              What about the Type R version? does it use the same suspension setup?
              But yes you are right, The design is a weird setup.
              Thats an interesting looking civic - we don't get the coupe over here.
              Is there any travel when you push up and down on the car, or is it solid?
              My 5.7 LS1 Holden Ute
                i hate doing rear speakers in those coupes!
                i always charge extra for them
                Member Ride Facebook
                XBOX LIVE = RedDragonsFool
                SOLD MY CB JUNE 16, 2009
                For Sale Thread
                  I am not awfully familiar with that car since we kinda don't have it here. But around here all 02-05 Civics and RSX have the same setup minus rear disk brakes and sway bars and such.
                  Gary A.K.A. Carter
