Throttle response
    Throttle response
    what mods can i do to raise throttle response? i have the F22a6 already with a SRI and exhaust. anything else i can do to raise it?
    what about OEM options? is there anything i can do to the motor, throttle cables, or anything else, that i can do to the motor(thats not needed for me to buy something) that can raise it?
    tighten up the throttle cable
      is there a certin amount to tighen it up by? i did that before and it raised the idle too much and when i come to a stop it would still be trying to pull forward and the idle would be at like 13oo
        You have to do it right, you obviously tightened it up too much and did not allow the TB butterfly to default to closed position. Find out where the cable needs to be minimal for the default position to always hit full close. You should feel it close. This is the tightest you can be without problems.
        Common sense really.
        Also good maintenance on your motor, clean out your intake manifold, etc with seafoam, throttle body cleaner at butterfly. Just make sure your motor overall is running well. Fuel cleaner in tank, etc. Good plugs, wires, etc.
          lol. thanx man. anything else?
            Yea, buy one of them Tornado things for your intake.
              lol. oh funny
                From personal experience, I'd suggest a Weapon R throttle rotor, it's the same throttle response but w/ MUCH less pedal travel, it's a really cool mod. I realize it's not OEM, but for about $20, it's worth it! If you have the throttle cable as tight as possible, it has a nice direct feel to it.
                From nonpersonal experience, I'd say a lightweight flywheel.
                  wieght deduction.
                    H23 Plenum.
                      Arias 12:1 pistons.
                        272 regrind + 950rpm idle = throtle respons
                          Yes.
                          Regards from Oz,
                          John.
                            From non-personal experience, I'd say a lightweight flywheel.
                            its an auto
                            but i might try that 1st idea you had tho
