Could it work?
    Could it work?
    Hey I got a free intake with the Si that I just bought. It is a 3in SRI for a Civic. My question is would I be able to hook it up to my 1993 Accord with or without some modification?
    1995 Ford Taurus SHO 5 speed-DD and stockish
    1991 Honda Accord- H22a and lowered DD#2
    2005 SRT-4 ACR package-stock at the moment
    should just that the TB is 2.5 so your going to have to get a 3"to 2.5" coupler or just crank that bitch tight
    wat?
      re
      sweet. when it warm up a bit I prolly install it then
      Its like 10 here right now
        re
        Will this require any modification to fit?
          Probably. You're trying to get a civic intake to fit an accord. If the 2 chassis were even slightly related, then you'd probably be able to drop it in, but they are completely different cars. You're gonna have to do something.
            re
            That what I figured. But thought I would check.
              yeah best bet would be to get a 3-2.5 inch coupler, that way, if you want to upgrade to the H23 TB/Plenum swap, its 62mm inner diameter and about 2.5 inches outer dia. so that would be perfect. but for now the accord TB is 57mm on the inside and about I'd say 2.25 inches O.D. But yeah I'm rockin' a 92-96 prelude 3" cold air intake on my EX w/ ABS and a strut bar and it amazingly cleared all that stuff.
                re
                That awesome to hear. Then I may wait to install the intake. I have a H23 TB and Intake manifold also waiting to be installed as well. I prolly just do it all at once then
                  it takes 7 minutes to take the intake in and out, why wait?
                  life is short.
                    re
                    Yeah I know. Just depends on how much modification it requires. Also becasue as soon as it gets a little warmer, I plan on putting the manifold on. Too cold to do it right now
