Somy friends bought a ecu flasher burner, so we can burn our own chips, feul maps, so im going to run a chipped p28 and start tunign with our wideband 02 sensor. ill let you know how it turns out
chipped p28 wit apexi safc 2 soon for f22
sorry for the late reply...this is midnite racer x by the way
Let me know how the chipped p28 works out. I've heard u'll definately throw vtec codes tho. What kind of program are you going to run on the ecu? So far most everybody thats going into the chipped ecu thing is using uberdata so let us know what u use. And most importantly keep us updated on if you are able to get the car to idle and run like stock or close to it. Let us know ur trials, tribulations, and triumphs. Share your map for the advancement of f22's everywhere.
Ok well update my friend is getting the ecu chipped as we speak, i believe we are moving over from p28 to a po3 i think, ill double check that, its from an older civic, but once its chipped i know were using uberdata and his wideband o2 sensor so were gonna try to get the a/f ratio almost perfect and then ill dyno for you guys out there!To have loved and lost is better than to have never loved at all #CB7Life
http://www.cb7tuner.com/vbb/showthre...threadid=10335
way ahead of ya son. Also u might be using the p06...never heard of the p03.Knowledge is power...in EVERY sense of the word
