Blacktrax Intake Manifold Spacer
    Just posted pics on the first page.
      Originally posted by HondaFan81
      I'd send another TB to get bored out or have www.maxbore.com (Jorge) fix yours. You're just asking for problems man, vacuum leaks.
      i know bro, i was just thinking..."high idle"
      I <3 G60.
        i see improvements in my car without a dino. hmm its good to have some kind of proven results. did you have any problem with your car. any vacuum leaks? car idleing at higher rpms. hmm i think i have to get some kind of gasket for the spacer.
        miss my turbo cb7
          no problems what so ever and yes u need an extra gasket
            how would we go about bypassing the fiv and throttle body coolant lines? Is it Ok to run this way, with stock ecu? Wouldnt this cause high/erratic idle?
            WaC!
              Are the bolts included
                only when u buy two of these spacers, if u only buy one u have to tell them to include them, or u can buy them at your local hardware store. Look at my DIY thread and the size of the bolts are there just read the second post on it.
                  if you buy a BTP IM, they should already give you one IM Spacer.. i got the additional for just a little bit more.
                  http://blacktrax.net/BTP_IMS.html
                  http://blacktrax.net/btp_H22_IM.html
                  My current setup:
                  BlackTrax Performance Stage4/Turbo Intake Manifold
                  BlackTrax Performance Intake Manifold Spacer (2)
                  So you on BAP? I'm OG on there!! lol! Also, I met Nat n Jei before they even opened BTP... If you ever go back, tell them I said "wassup!" hah
                  Omar | aww_shiet | Facebook | Instagram
                    My current setup:
                    Yup im on bap my screen name is greencb7 over there. I got a few things for them to do for me so, i'll tell them u said hi
                      new dyno looks promising! now where are the gains coming from increased manifold space or cooler air temps?
                        from both, but mostly from the increased space
                          How much space do you have left? It looks as though using 2 would increase even more...
                          What if you trippe stacked? Would you even have enough clearance...
                            so those dyno's are with the spacer AND the stock IAB right?
                            Did they do anything else? Like re-chip? I can see the other mods...so I'm wondering what else needs to be done with this setup...or if it's just a bolt on and run
                            ____
                              did u read it says no tuning done
                                so whats the verdict of using these with a boosted car? Anyone know if it will hold up or not? if it gave that kind of horsepower and torque to an n/a car and can handle boost......think of the possibilities....
