Throttle Body bore
    Throttle Body bore
    what size do yall think i should get my TB bored to? i dont want to go too extreme and i dont want to do just the bare minimum.
    im thinking about sending my TB to maxbore.com to get it woked on. any suggestions?
    how much does it cost to bore it out from maxbore? im thinking about doing mines to for turbo.
    miss my turbo cb7
      $100 for all honda TB and $135 for non-hondas.
      i just need to find out what would be a good bore size to go wih. i dont want to get something to extreme.
        With the details you have given, no one can give you a size.
        What are your current mods/future plans.
        If you're stock, there's not much reason to bore your tb. I recommend that you get your IM port matched if you do decide to bore your throttle body.
        You need to have some supporting mods to take advantage of the extra air coming in.
          maxbore f22 & h22 bore out to 64mm.....jdm h22 type-s 66mm
            Jose is right, y'all need to do some researching and learn, learn, learn!
              yeah i thought about getting the IM port matched. no point in getting a bored out TB and have the IM messing up the airflow.
              as far as future mods, i wont be doing anything more than a 50hp shot of nitrous in a few months. I/H/E will be done within the next month. and an f22a6 IM within the next week.
              for right now i was going to send out the TB just to get it bored out so i can have it for later when i get another motor that ill be boosting. i just wanted to figure out what a good size bore would be good for a boosted set up. no more than like 8-10psi.
