---- 12:1 All Motor F22 Project ----
    Car: 1992 Honda Accord LX
    Motor: F22A SOHC non-vtec
    Transmission: ????
    Goal: 200WHP
    BLOCK
    - Custom 12:1 DHR 86MM pistons
    - Thermal coating on piston dome
    - Probe Connecting Rods w/ ARP rod bolts
    - OEM rod/main bearings
    - Unorthodox Ultra S Crank Pulley
    - Toga high volume oil pump
    CYLINDER HEAD
    - Ported and polished head
    - Bisimoto stage 2 camshaft
    - F22parts single valve spring upgrade
    - F22parts titanium valve spring retainers
    - F22parts valve locks
    - Megan Racing Adjustable cam gear
    INTAKE
    - Ported and polished H23 intake manifold
    - Heat shield gasket
    - H23 bored throttle body
    - 3” intake piping
    - Air starting valve block off plate
    - EGR block off plate
    IGNITION
    - NGK iridium plugs
    - MSD plug wires
    - MSD SCI Ignition box
    - Stock coil (maybe MSD coil)
    TRANSMISSION
    - M2B4 (I hope) ---- may stick with the F22 for now or H23
    - Stage 3 clutch
    - 8lb flywheel
    EXHAUST
    - Kamikaze 4-1 ceramic coated header for EX application
    - 2 1/2” inlet/outlet high flow cat
    - 2 1/2” mandrel bent stainless steel piping
    FUEL
    - H22 injectors cleaned and flow balanced
    - Megan Racing adjustable fuel pressure regulator
    - Walbro 255 fuel pump
    TUNING RELATED
    - Hondata S200
    - Chipped PO6
    - Tuned on 92 octane
    - Dyno tuning expenses
    MISC
    - OEM seals and gaskets
    - Oil pressure gauge
    - Air/Fuel gauge
    - Battery relocated to trunk
    - Synthetic Oil 5w-30
    Midwest car club
    Current rides:
    91 accord lx (5spd)
    92 accord lx (5spd)
    93 accord lx (auto )
    Teaser pic :P
    Midwest car club
    Current rides:
    91 accord lx (5spd)
    92 accord lx (5spd)
      (.space reserved)
      Midwest car club
      Current rides:
      91 accord lx (5spd)
      92 accord lx (5spd)
        (space reserved.)
        Midwest car club
        Current rides:
        91 accord lx (5spd)
        92 accord lx (5spd)
          (.space reserved.)
          Midwest car club
          Current rides:
          91 accord lx (5spd)
          92 accord lx (5spd)
            (..space reserved)
            Midwest car club
            Current rides:
            91 accord lx (5spd)
            92 accord lx (5spd)
              (...space reserved)
              Midwest car club
              Current rides:
              91 accord lx (5spd)
              92 accord lx (5spd)
                Yea buddy, my F22 all-motor brotha! Glad you finally made a thread for yourself. I can't wait to roll out with you and take on some people, total sleeper style!
                I'd ask your dyno tuner about running an EGR block-off plate. I asked Kelly, my friend that's a mechanic, he was saying how doing that on some motors may throw off your ignition tables. Something about not need as much timing advance with an EGR valve blocked off because of differences in intake temperatures, etc.
                Keep it up!! I'll get you the parts soon.
                  I do remember actually reading something related to that. I'll get into contact with the dyno shop and see what they have to say. If it comes down to it, I'll just keep the EGR valve on and clean out the ports really well.
                  Midwest car club
                  Current rides:
                  91 accord lx (5spd)
                  92 accord lx (5spd)
                    Actually, new findings:
                    P06 ecu is from a 92-95 civic, which supposedly had no EGR valve. Today when red Accord was warmed up and idling, I removed vacuum hose (plugged up hose with finger) and it idled fine. I think using this chipped P06 ECU already eliminates the use of the EGR, but I'm going to put a block off plate on both cars eventually, for peace of mind in case the EGR valve goes bad.
                    So nevermind, go for it. Doesn't seem to make a difference. The dyno tuner at my shop said he doesn't do anything differently really between EGR vs non-EGR cars that come in. Bseries don't have EGR he said as well, so if they can run without, ours should.
                      Yep we can run without EGR. Just NoX emissions gonna be higher and such.
                        please keep us up on the updates. i really want to see both this and hondafans white project completed. i really hope everything pans out for you on this.
                        -sean
                        Members ride 15.927 @ 86.76 (f22a1)
                        Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
                        Arcadia Green Crew #10
                          -sean
                          Cisco is more then likely going to be finished before me. I'm shooting around mid-end of summer to have this completed.
                          I'll get around to posting pics later of what I have so far.
                          Midwest car club
                          Current rides:
                          91 accord lx (5spd)
                          92 accord lx (5spd)
                            You know I'm down for helping you out. You're not too far, just stay focused bro. Only reason Nate's going to take longer is because he's in school now, but that's a good thing. We'll get'r done. I'm doing what I can to help him get parts, etc.
                              Wow thats a nice list u have there .
                              Vouches: Bruno8747, 1badwag, Excalibur02, Bliz07, Slick, Gloryaccordy, H23CB7.
