sounds like you needs an engine damper ;]
build up of JDM F20B DOHC VTEC
Originally posted by fatboy1185the car is drivable now. runs like a charm. i cant believe the engine movement though. that is how my throttle cable got screwed up to. the intake manifold slammed against the firewall also, pinching the cable.
this summer i plan on pulling the motor and taking care of a lot of little problems
holy crap eli this is the reason why i dont drag or launch at 4k or even launch for that matter, i say dont half ass that tranny fix take it to a shop to be welded, then check and recheck and recheck EVERYTHING. hope ya get everything fixed
PSN ID's:Tidashoni
1992 Accord EX Coupe
My FS Thread
Originally posted by deevergoteBoosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
Originally posted by HondaFan81Sounds to me like this project was half-a$$ put together. You should have known the condition of your engine mounts and attended to them while working on this motor. This should have never been an issue and only is due to lack of attention. If you understand the transverse layout of your motor, you would understand the front and rear mounts are the most important based on engine torque/movement front-to-back and vice versa. It is said that your tranny case fractured, such a nice tranny and for this to happen to it.
Originally posted by fatboy1185i agree 100%. attention wasnt paid to where it needed to be paid, and this project was super budget based. this summer the motor is being pulled and everything will be taken care of/repaired.
finally. had to remove the rear backet, twist and push it to the side until i had the perfect angle to squeeze the old mount out and shove the new one in. Took me quite a while to say the least. wet pavement, and hail didnt help either. but im happy. hopefully this will keep my motor from slamming into my firewall
Went to the track for the second time. sorry no video's, i was all by myself Much better results this time, i improved every single run. My best ended up being a 14.423@ 96.72. With a 2.319 sixty I feel with a 2.1 sixty footer, 13.99 is realistic. I can always hope anyways, here is a few pictures i took.
I'm car #4183
This truck kept owning me (ran low 12's)
High 11 second corrado
Junior drags (also had pro drags running 7's, but i didnt get any pictures)
just some nice cars
You need traction.
