pics of my itb setup
    well here are some pics of my TWM 2000 series itbs. they are 52mm each.
    i just got the rest of my parts from the machine shop today, so hopefully these things will be on the streets by next weekend.
    i like those alot
      What's your engine setup? NA, turbo, nitrous or a combo?
        Hook me up with one for the h22a = D
        ill pay for it
        ~Cole~
          damn you, i wish i could afford itbs, what are you going to tune with?
          Members Ride
            well ill be filtering by a box that TWM makes. its a couple hundred bux so it may be a lil bit before i get it.
              Oh wow TWM = $$$$ Nice pickup though.
                well im runing an h22a1 block with a balanced and polished f22 crank and rods. (acts as a stroker) type s pistons (which gives me 12.12:1 compression), rebuilt head (which will be port/polished and valves over the winter), skunk 2 cam gears, those itbs, aluminum flywheel and dual friction clutch, 2 1/2 header back exhaust, aluminum crank pulley, no balance shaft, msd iginition setup, heat wrapped header, chipped p28, ngk iridium plugs and wires, vafc2 for the hell of it. im taking it to a local shop to have it dynoed and tuned. thats all i can remember right now. if i think of anything else ill post it up.
                  damn, those look soo sick.
                  My H22A SWAP JOURNAL
                  Members Ride
                    Those are tight man but will it clear the back of the firewall since the motor flexes?
                    My CB For Sale
                      yeah it will clear just fine. also we (my buddies and i) are poly urethaning my mounts so it will be a lil stiffer.
                        What numbers are you planning to run? Hows the 12.12:1 Compression on pump thats pretty damn high but should net you some damn good numbers.
                          dont have a clue dude. i dont know what its capable of. i will be running race fuel alot. lol. i was doing some research and can get away with 93 octane but i cant go any less.
                            I want those. I always have lol. The carbon fiber look is pretty sick too.
                              Yea that requires some tuning. 12:1 is the max I would go with a street motor but if your gonna be running race gas you should be fine. Its just gonna cost a bit more lol like what 5 something bucks a gallon or something like that.
