i dont see why you wouldnt be able to break 15's with a modded auto, especially with the mods you are going to do, sean.
h22a mods for 13's
Originally posted by gloryaccordyH22sparkle's car has a Type-S motor and is completely gutted with a rebuilt LSD tranny and racing clutch/flywheel, and honestly I don't even know if he could pull 13s...maybe on slicks. Short of a complete teardown and rebuild I can't think of any way to get into the 13s N/A with our cars.
Hondafan81 why do you think I made this thread?(Not pickin on you XD) To get advice and suggestions, I dont want to go waste money any old parts. I want to get the ones that will make the difference . People are just starting to post about anything thats barely related "Oh the h22 this or that..." I dont want to know if the h22 can do 13's, cause I know I can, I want suggestions on whats your setup if you are running 13's or lower/what DO YOU THINK are the best mods for the money, Thanks again to people who ACTUALLY gave advice...Originally posted by deevergote..It's not cheap to build a fast CB7, especially NA. However, if you're willing to put the money into the car, it's well worth it in the end. There ARE faster cars out there, but some people, like me, want THIS particular car to be fast!...
1993 H22A cb7 <3 miss you
04 WRX stg 2 sedan
Current - 02 WRX stg 2 wagon
The only person that's not turbo or juiced running 13s or lower is 2point6. Performance is his business, so unless you pay him to work his magic, I don't think any secrets will be shared.
If you want to sleeve an H22 and run forged pistons, 13s are cake with turbo. If you want to run nitrous (with or without building the internals... without presents some risks) then you'll also be able to hit 13s easily enough.
idk more research i do the more im leaning toward nitrous, just cause money is tight with college and all and that seems to be the cheapest solution to go quick. Then again I need reliability and I dont want to run into any costly problems. Just somethin about all motor when you get it done right that makes it feel like more of a accomplishment then just hooking up a 75 shot. Then again doing a turbo buildup seems like it be pretty neat. Gah, options... all boils down to the $$$. hmmm deevergote ya got me thinkinOriginally posted by deevergote..It's not cheap to build a fast CB7, especially NA. However, if you're willing to put the money into the car, it's well worth it in the end. There ARE faster cars out there, but some people, like me, want THIS particular car to be fast!...
04 WRX stg 2 sedan
Don't discount the electric supercharger either... www.boosthead.com
That design is actually pretty worthwhile.
Personally, I'd do short ram intake, bored TB, ported intake manifold, most aggressive camshafts you can deal with/withstand, headwork by someone who knows how to tweak an H22 (cuz it already flows well stock), custom header and atleast 2.5" - 2.75" (talk it over on what's best). I would not bother with the bottom-end but make sure things are in order with new seals, belts, etc. Do a full tuneup on the car and clean certain parts, remove the A/C and P/S and any other weight you can remove and feel you do not need. I'd lower the car, better tires/rims, stiffen up suspension, mate a JDM H22 LSD tranny 5spd. Get the basic fuel psi guage, fuel psi reg and cam gears. Tune your shit well. If that still don't work (for whatever reason) then use nitrous.
good clutch and 8-12 lb flywheel
well personally im gonna go with usdm h22 trans, jdm h22a, with exedy stage 2 clutch, fidanza or something similar flywheel, ported head ferrea oversized valves, skunk2 titanium springs and retainers, and rocket motorsports cams, type s pistons and a slightly milled head which should get me close to 11.5:1 c/r, all tuned on hondata s200b with launch control i hope to hit 13.9 or maybe a lil bit better with a stripped car we sall see.... anybody wanna recommend a dragradial?
oh and dont forget about my itbs shortly there after
same here, only thing is how much are them battery packs? Sounds like it could get expensive and weight could become a issue. idk i dont think i have the cash to go all out N/A with me going into college and all. The bottle seems like a good alternative...Originally posted by deevergote..It's not cheap to build a fast CB7, especially NA. However, if you're willing to put the money into the car, it's well worth it in the end. There ARE faster cars out there, but some people, like me, want THIS particular car to be fast!...
04 WRX stg 2 sedan
Originally posted by J-specCb4well personally im gonna go with usdm h22 trans, jdm h22a, with exedy stage 2 clutch, fidanza or something similar flywheel, ported head ferrea oversized valves, skunk2 titanium springs and retainers, and rocket motorsports cams, type s pistons and a slightly milled head which should get me close to 11.5:1 c/r, all tuned on hondata s200b with launch control i hope to hit 13.9 or maybe a lil bit better with a stripped car we sall see.... anybody wanna recommend a dragradial?
