Hmmn. Changing Rods to bump Compression ratio...its a thought. Just not well thought out.
Not to TKO this, but H22 rods AFAIK do not work with the 95mm Cranks because they run into the valves. You need the 89/90.1 Cranks to use the H22 rods.
Givens:
-H22 rods are longer.
-Longer rods equal shorter TDC and BDC distance which causes quicker piston speed at the expense of torque.
-Longer rods also mean the piston may reach closer to the head.
To be deduced:
- Piston travel that is closer to head will increase CR. CR is the ratio of the mixture to used volume in the Combustion Camber. Less space = Higher concentration which means higher CR.
Now the TKO: You need a really thick HG. Which is not practical. TypeG says mill head (most economical option). Pistons (not economical to say the least). You really played with the piston to deck number there, which is factored in CR. A+ for effort.
Givens:
To be deduced:
