I would like to see some NA f22a dyno results. Stock or not.
looking for your f22a dyno results
In a Prelude but still an F22A1
Stock block
AEM cold air
Thermal catback
NGK Iridium plugs
Bosch wires
118.05fwhp / 135.92ft/lbs
can get the dyno sheet scanned in here if you want to see that too1993 Prelude S
F22A1
custom'ish turbo setup
180 whp/217 ft-lbs super hot, super humid, super rich, boost falling off at 8psi
18psi boost spike = BOOM!!!!!
currently being rebuilt
176whp 142tq
Generic short ram
Extrude Hone A6 Manifold
50lb/hr injectors
Ferrera Valves
Crower Dual Valve Springs/Titanium Retainers
Delta Regrind
12.5 Wiseco Pistons
Crower Rods
Darton Sleeves
Kamikaze Header
AEM EMS tuned.
Will be running a dual stage 70hp/200hp shot to make a total of 446 to the wheels.Last edited by 93accord; 02-03-2006, 06:00 PM.
CB7Tuner member #38
Originally posted by 93accord176whp 142tq
Generic short ram
50lb/hr injectors
Ferrera Valves
Delta Regrind
12.5 Wiseco Pistons
Crower Rods
Darton Sleeves
Kamikaze Header
AEM EMS tuned.
kinda surprised it didn't put down close to 200whp...anyways here ya go. Stock f22 with intake, exhaust, and me messing with a chipped p06. Theres a very dim red line there also...that was the stock ecu
im thinking of dyno in the spring just for shits and giggles, any more scans?
mullet: what tranny was in the lude?Last edited by starchland; 02-04-2006, 03:04 AM.
Originally posted by 93accordWhen I made the 176 hp dyno pulls my HG was leaking compression. Since then it's been fixed, and I'm sure I could hit 200whp with some more ignition timing. The timing wasn't adjusted beyond the basemap that comes included with the EMS.
JUST KIDDING!!! THOSE ARE H22 NUMBERS!!!! What's your redline man? And did you put your pistons in?
Originally posted by lordojaim with you on that one bro! aint nothing beat free food and drinks any day of the week, even if its at a funeral
Originally posted by gloryaccordyThat's what I figured. Your numbers seemed really low.
I spin it to about 7250 at the track, but HP starts dropping off around 7k. I built the entire motor, only things I didn't do was install the valves springs and retainers and the machine work. I would have build the head myself, but I needed someone to work up a dual valve spring solution with respectable parts, the last head I had built by JG was a joke and cost me just as much as this one.
CB7Tuner member #38
Originally posted by 93accordI spin it to about 7250 at the track, but HP starts dropping off around 7k. I built the entire motor, only things I didn't do was install the valves springs and retainers and the machine work. I would have build the head myself, but I needed someone to work up a dual valve spring solution with respectable parts, the last head I had built by JG was a joke and cost me just as much as this one.
The Delta 272 grind specs are pretty close to the regular (non Type-S) H22 high cam specs, by the way. I think the lift is a little lower to keep the car driveable at low revs...
Originally posted by HondaFan81Yes. Boring, honing, decking block, crankshaft inspection and straightening, balancing of rotating assembly, etc.
CB7Tuner member #38
