i currently have a F22a6 intake manifold but im wondering what the gains will be if any from using a H23 intake manifold (tb included), thanks
F22a6 im v.s. H23 im
the h23 will give u slightly more gains, u wont feel it as much as if u went from f22a1 to h23 but it will be there. the tb is bigger which will help. i think the bottom half of the IM is exactly the same but the upper plentium is what will help. ask granitecb7, he is in the process of doing this to his a6
http://www.cb7tuner.com/vbb/showthread.php?t=12927
I actually had both intake manifolds, this thread has pics and written detailed comparison. I renamed the thread as it took me a bit to find it, should be easier to find in a search now. I measured runners, etc.
Originally posted by HondaFan81http://www.cb7tuner.com/vbb/showthread.php?t=12927
That is the one I was thinking of!
As someone previously stated and more...parts that interchange or are same and parts that are different...
Same/Alike Parts:
- F22a6/H22/H23 IAB plates w/vacuum diaphragm (butterfly valve plate)
- H22/H23 throttle-body
- H22/H23 intake plenum (upper-half of intake manifold)
- F22a6/H22/H23 throttle position sensor
Parts That Are Different:
- H22 & H23 intake runners
- F22a6 throttle-body vs H22/H23 throttle-body (2mm larger than F22a6)
- F22a6 vs H22/H23 intake runners
