Milling Head
    Milling Head
    Sorry if this is been posted before, but I searched old threads and couldn't find the info I needed.
    So I'm thinking about milling my head .020"-.030" and getting a Delta 272 cam regrind. The cam will increase the lift of the valves(I think), am I going to run into interference problems??
    http://www.cb7tuner.com/vbb/showthread.php?t=15870
      all that site says is might be different for different cams??
      does anyone know the stock cam specs (lift and duration?)
        go to honda and ask them there, they should know.
          The factopry intake lift specs on the 2 cams are:
          A1/A4: 1.5167"
          A6: 1.5252"
            So the a6 cam IS different...interesting. To ensure u don't run into any problems clay the motor.
              holy thread revival.lol
              damn, good info tho, cisco should take this info and put in a sticky.
              -Jose
                I'll get the exhaust lift specs tomorrow but they also differ between the two cams.
                  wait a minute...it can't have a full inch of lift that's insane...can u re-check your specs cause even the 272 regrind only has like .390" lift and extremely agressive cams only have like .450"+
                    You have to subtract base circle from that measurement. So why it has that value instead of the value minus base circle is beyond me but I don't have a cam out to mic. so you're on your own on that. That's just what Chilton's, in all their realms of wisdom, put on the spec chart.
                      So if someone were to take a stock F22a1/a4 and F22a6 cam and use a micrometer to measure perpendicular to lobe on the cam, you would find the diameter of the base circle and could subtract it.
                        -Jose
                        Tengo mas informacion de que tu sabes, senor pendejo.
                          te crees muy perron pinche puto. Que no se te infle la cabesa.
                            Yeah.
                              I did have trouble walking thru the door today
