i have a problem on my car..my car is idleing erracticly...rite when i turn on my car...it idles at 2,500(that's normal)but when it idles that high..it automaticly drops to 2,000..2,500-2,000..continously...then when it hits warming point...it goes frm 1,500 thru 1,000...automaticly...it doesn't stop..it just keeps going...it sounds like a vacum leak but its not..i check all my vacum hoses and it's all connected...im also thinking that i might be leaking on my egr valve..but i can't seem to locate it...could it also be my gasket...??..does any of u guyz have this problem...can u guyz pls help me in this one.....im lost.....
Motor!!!
sorrie bout that...i've been busy lately...my motor isn't slughish...it's running hella fine..trust me...nothing is up with my motor..but that erratic idle....that's the onlee problem..let's see...i took out the intake pelium...and the throttle body...and there's that one thing that is bolted on to the manifold...where there's a harnest to connect it...the one for the fuel injectors..and there's a hose that connects to it..the one for the coolant...it's rite under the throtle cable..the one that connects to the gas line....i didn't really get to tighten it...i onlee tight one side...i think that may be the problem...one more thing..i also just remebered..that..my car use to do that when i don't start the car for about 1hr or so..just aslong as the motor is cold..but it won't do it rite away..it'll stay up for a while like how it should..then about a min or 2...it'll start doing that..then when the motor get's a bit warm...it'll stop....and frm what i heard..it's my tps(Throtle Position Center)....but yeah...i hope this is enough info's...
There's a thread in the DIY section covering this. I had the same problem with my car. This fixed it. Check the photos and read the thread. Essentially all you have to do is tighten the white thingy every now and then. You don't need to take anything apart to get to the white thingy. Simply undo two screws and remove the cover plate.
By the way, anbody know what that's called and where I can get a new one. Mine comes loose every couple of days. Thanks
