Let's just say this thing has serious potential for a street manifold when ported. Yes, the runners are smaller in diameter than the H22's, but for an ideal torque peak in the 4800-5500 range, the F23 just needs a little bit to be just about perfect. A little over 2" square for area. The potentially huge plenum easily rivals that of the H22, this is definitely the choke point as cast which makes the engine draw vacuum and flatline around 5000RPM. The F23 is wider, deeper, but shorter front to back than the H22.
H22 butterflys on F23 lower
Post-porting pictures and before/after dyno coming soon.
