Well I've done a lot of searching and it seems like a lot of options are no longer there, so a lot of info in threads is irrelevant. Either way, my f22a1 has 350k KM on it, and its been abused by the two owners before me. She burns a little oil to say the least. This fall/winter I plan on rebuilding the bottom end and I want to do it as budget/diy as possible.
I went drag racing last weekend and it was a BLAST! I was the underdog against tons of big muscle but still had a lot of fun on the 1/8th mile with regular times around 10.424. I want to go faster, and I want to stay N/A.
Currently I have a 68mm Throttle body, Port matched double-stacked IAB intake manifold from an H23 with working IAB's going into a lightly cleaned up head with a Delta 272 regrind cam. Cheap 4-2-1 header, no cat, and a 2 1/4 exhaust.
Currently I'm learning to tune on crome on the street (no dyno near) but I will probably switch to neptune for better support and built in logging. The car seems to be ever changing and is hard to get a solid tune. Its old and tired and things are wearing out, but they are getting changed and fixed as I go.
I would like 200whp, and I would like to do most of the work myself. I was looking at some high compression pistons but at 600$ USD that works out to be DANG expensive up in Canada with our bad exchange rate.
So what about some of these DSM piston options, I only could find info for turbo setups where everyone was lowering the compression with different rod combos. Is there something that would work with shot peened stock F22 rods and gain me some compression? Or do I have to shell out the big bucks for forged.
And then I'm going to need valve springs. It seems like Bisimoto is out of their f22 springs (and getting out of all honda stuff) so where else can I find some "performance" springs without breaking the bank.
I know there Is no free horsepower, but I don't think My goal is too far fetched.
Any Ideas would be much appreciated!
