So while doing some research I had learned about the h22a1 and h23a1 and that they were "closed deck". I ended up picking up a h23a1 for 100$ and after looking at it I would have to lean towards calling it more so of a stock block guard. Still useful but I had my hopes up but still have a build planned because i was given a h22 head .
The "closed deck" h23a1 block
Because isn't the block guard installed at the top of the sleeves? I may have been misinformed on what an actual closed deck block is, but to what I have learned it's suppose to be closed all the way down the sleeve with smaller coolant passages.
When I saw a block guard that's what this "closed deck" on this h23a1 looked like it just appears to serve the same purpose. I mean the block is still a little stronger when compared to open deck no?
It is stronger. Not much, but some. Calling a closed-deck design similar to a block guard is like appreciating Edison's accomplishments over Tesla's, though. The closed deck concept came first and the block guard was a means to imitate that.
So anyway, what's your question?My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Closed deck is when deck is closed. It's not the entire block that is filled in.
A block guard and a closed deck H22/H23 look nothing alike.
Open deck;
Closed deck;
Block guard;
the closed deck doesn't make the sleeves any stronger. It keeps the cylinders from moving under high RPM or high boost. Open deck engines have a tendency to have the actual cylinder walls move.Last edited by GhostAccord; 08-15-2013, 12:07 AM.
Originally posted by deevergote View PostBlock guards have a tendency to shift, whereas a closed deck block will not.
Block guards are also known to warp cylinders.
