I am not asking about where or what kind of performance out of a certain brand of camshafts, but why in the hell is Crower Stage 1 cheaper than OEM from RockAuto by about $400?
H23 Cams
H23 Cams
Be unique, like every other person.
CB7 Sold________________________E34 Sold________________________E39 Current
Tags: None
It just really surprised me.Be unique, like every other person.
Originally posted by XCRN View PostIt just really surprised me.The CB7 Collector.Team Kindred Impulse Member #392 LX Coupe F22A12013 Toyota Corolla S92 EX Sedan F22A1Originally posted by deevergoteDo you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
Exactly. I might need new cams but I am no expert in the matter. If the cams that came with the engine are good, I will save the Crower for a different day.Be unique, like every other person.
Be careful if you do the cam switch... did a stage 2 upgrade on mine and they said I wouldnt have to shave or press the valve guides down any but when I changed my oil I found lots of peices of tiny springs and rubber from where the cams chewed up the valve guide seals. had to go back to the machine shop who put the head together and "checked" about the clearance and made them fix it for free, just something for you to keep in mind to look for if you do swap them.
Originally posted by deevergote View PostCams usually don't get so terribly worn that they need to be replaced. If they do, then that's a very clear indication that something else is likely to be very very wrong.
A cam can snap, but that is similar to a broken timing belt... with similar carnage as a result.Be unique, like every other person.
