Bisimoto Built Head
    I used to have a guy at the local Honda dealership. Got mine for $175. Not sure if the cores you get from other shops are New or used for $150??? They could be new cores that you buy from them????
    14111-PT4-F50 - $310 @ hondapartsonline.com. Would be worth the $150 if the cores from Bisi are new!
    MR Thread
    GhostAccord 2.4L Blog
    by Chappy, on Flickr
      Ok so first things first. Friday I set up an appointment with the Honda dealership to do my front brakes because they are down to nothing. New pads with turned rotors are 165 with taxs that's out of the way. Next thing is my muffler is completely shot, it rattles from the inside and vibrates so hard it's insane. Getting attention for all the wrong reasons. So I'm going to order a k teller exhaust piping kit 2.5 or 2.25 haven't decided yet and try to find I great sounding DEEP muffler for the end of it.
      I wake up in the morning and piss excellence!
        If you are still planning to do an intake manifold upgrade, level 2 camshaft and custom header. I would go with the 2.5" K Teller kit.
        Then go with a 2.5" Flowmaster cat, 18-22" resonator in the B pipe and a 40 series Delta Flow after the axle..... That should be deep enough!
        MR Thread
          Thanks for the input! I was gonna start searching around once I got to work tonight trying to get it all pieced together. I'm gonna start a second mrt for my new coupe and should start showing the build there 8)
            I've never been keen on flowmasters. Poor construction, baffles cause a decent amount of restriction, they throw off exhaust pulses which effects scavenging and they rust in a matter of a few short years. I'd definitely go with something with no baffles. There are plenty of ones out there. I know how I made mine deep.
            Vibrant 2.5" super quiet resonator
            Vibrant 2.5" 6" round muffler
            Vibrant 2.5" stealth dual tip muffler
            Ktellar 2.5" piping kit
            Don't mind the crappy camera.
            MRT: http://www.cb7tuner.com/vbb/showthread.php?t=95154
              Parts search is ON and new mrt has been made.
                Originally posted by jdm92_accorn View Post
                i promise you bro, ive done this a few times. find a local machine shop you can trust. port the exhaust side and leave the intake alone. get a mild camshaft, ie bisi level 2 or delta 272. i personally like the bisi level 2+. a good intake manifold setup, like f22a6 runners with h22/h23 upper with ported and modified runners with a tapered s2000/itr/h23 vtec throttle body. a good header if you're broke a modified 4-2-1 header. a 2.5" exhaust and some good engine management and some sort of fuel upgrade. here is what i would do, save another $500. for $1500 id go this route
                3" blox velocity stack $35
                3" ebay intake $40
                s2k throttle body $75
                bored and taper tb maxbore $110
                f22a6 runners/h23 plenum $60
                bisimoto cam/valvesprings $600
                megan racing h23 header $160
                vibrant 2.5" 2-1 collector + welding $125
                k-tuned rdx injectors with hats & clips $260
                What's the difference in h23 megan header to the f22a megan header?
                  Originally posted by wildBill83 View Post
                  Or pick up where someone else left off, check this for sale thread:
                  http://www.cb7tuner.com/vbb/showthread.php?t=183645
                  ^that is a nice head in there for $600 complete. Now that is a good starting point. The head is of a running motor, so you know as long as it is shipped right you can use it as is.
                  I contacted seller about the head for sale. He us no longer selling 8/
                    so are you looking for a ported head?
                      I was going to pick up a used head at the jy and have it ported and polished but if I can find one for a good price IM on it 8)
                        Sraighter, longer and slightly larger primaries. Same price.
                          Good to know, I thought they were the same also.
