higher compression f23a1
    Originally posted by jdm92_accorn View Post
    you guys do know base model rsx pistons put it at 11:1 and a safer piston to valve clearance. F23A1 block/crank/rods, k20A3 pistons, F22A6 head, skunk2 IM, 70mm TB, custom header, and a custom grind from web cams and you'd have a 230-240whp brawler.
    So slighty higher compression and .1L of displacement more than what you're currently running and the results will be 50-60whp higher than your current numbers?
    And static compression ratio numbers don't paint the entire picture. The swirl bowl in the top of the K20A3 pistons is not conducive to use in an engine trying to make an efficient, powerful burn during the combustion process. And by the way, they would only make that combo have a roughly 9.9:1 compression ratio.
      Where are you guys getting these numbers from? It's so much easier to run a K20 piston in the F23. What was wrong with that idea (besides using K20 rods like Jarrett explained)?
      10.2:1 F-series, 417whp, 398lb/ft Single-Cam on pump gas
