In order to do it exactly that way you would need the H23A VTEC crankshaft which has 55mm mains. Good luck there.
BOLT ON: OEM H23 opinions
Originally posted by Jarrett View PostIn order to do it exactly that way you would need the H23A VTEC crankshaft which has 55mm mains. Good luck there.
EDIT:
NVM found the info I was thinking about here: http://www.roskoracing.com/H23Vtec.html
The USDM H23A1 has a 50mm crank.Last edited by wildBill83; 12-04-2012, 01:12 PM.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
Originally posted by 8ball View Post
Oh And I am trying to stay out of the engine. I Decided that Ill be using the F23A1 block (fresh timing seals gaskets) (*stock pistons*) with a F22A head that's been serviced for maintenance only ie servicing worn items in valvetrain milling and some port matching/cleaning (no special shit) Not even a cam. (no need no high compression pistons)
I expect the combo to give me like 130whp to the wheels.
The only mention of an h23 was for a Logic Motorsports header he is having made to fit an h23 flange, you have a bb6 intake manifold on a f22a head? The way I understand it is that isn't a match without an adapter plate. Also I don't believe there is anyway to reach 130whp without a tune, a stock p12 might net 140 crank hp not really sure if this combo would give anymore hp but certainly wouldn't with a stock tune. Just my 2 centsMy work in progress!
I think he means intake tube.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Originally posted by 1990exr View PostThe only mention of an h23 was for a Logic Motorsports header he is having made to fit an h23 flange, you have a bb6 intake manifold on a f22a head? The way I understand it is that isn't a match without an adapter plate. Also I don't believe there is anyway to reach 130whp without a tune, a stock p12 might net 140 crank hp not really sure if this combo would give anymore hp but certainly wouldn't with a stock tune. Just my 2 cents
Look guys I have a H23a intake manifold. complete. I want to clean it up a bit before it gets installed. I know black trax guts them out. I figure why not if skunk2 (and smiliar type for h22) doesn't use IAB why would I ?
Im willing to drop some coin on mods but nothing jaw dropping. Like a aftermarkt h22 manifold with a H to F intake manifold adapter or nothing like that.
And I already have lighter wheels and suspension done. I roll with out a back seat it helps but not really lol.
So as far as the BB6 intake its just the intake tube nothing else just the tube. I wanted to get a trilogic and weld the h23a flange on it. Might still do it depends on what a CNC/CAD machinist I know says about it.
Blacktrax doesn't gut the IAB. They provide a proper functional spacer. The IAB is still a very useful feature, providing low-end power AND high end power. It's like a smaller version of VTEC.
The manifolds that don't use the IAB are designed that way... and they're designed for high-revving engines.
Thanks deeve, I think they do offer a gutted H23 option. Well offered. Its discontinued. http://www.blacktrax.net/products/In..._Manifold.html
