So, I got this idea while reading the stroking H22 thread. Also, it's possible something like this has been done before.
Anyway, I was thinking about the issue of having the crankshaft and rods so long that they interfere with the deck.
Wouldn't it be possible to remove this interference by having the bottoms of the cylinders cut at an angle, which would mean the cylinders could extend all the way down to the crank journals if they wanted, and use a piston that also extends down like that angled cut on the sides, and also use piston rings that are formed to match that contour. I can draw a diagram if needed.
This would effectively increase the volume of the cylinder, and allow for crazy compression ratios. Does anyone have any idea what I'm saying right now?
