Honestly, I'd avoid installing a worked head on an old stock block. If that bottom end gives out and sends a piston into the head, that's a lot of money wasted! If you have a built block coming soon, I'd be patient and hold off. Install it all at once. If Bisimoto isn't far from you, and you can get your car there to have everything installed, that might be good. They're basically designing the engine, so having them install and tune it might be a great idea.
has any one heard of these guys ?
Originally posted by deevergote View PostHonestly, I'd avoid installing a worked head on an old stock block. If that bottom end gives out and sends a piston into the head, that's a lot of money wasted! If you have a built block coming soon, I'd be patient and hold off. Install it all at once. If Bisimoto isn't far from you, and you can get your car there to have everything installed, that might be good. They're basically designing the engine, so having them install and tune it might be a great idea.
02 Crv
OK lvl2 to it is then. thanks deev and SOHC-FTW .this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
when i get the head back it will be put away while i save for the block to be sent for a hone and fitment , pistons ,rods , bearings ,seals ect....ect..... and source a po6 ecu .
is my spelling better ? can you under stand me now ?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Just remember clearances need to be checked (Rods,mains,P2W etc) before buying any parts. Also a good machine shop will ask for the piston's before boring.
02 Crv
that's why i am sticking with one shop one guy .this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
i got my mind set that its ether going to be bismoto or the barber shop .this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
head sent to bisimoto today.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
good luck with build f20b dohc screamin meanie i have one its a revvvvvvvvvvvvvvverrr but also built a f22 with a few gude parts lol i was impressed it dynoed at 193hp cant remember everything else ill look for slip but it reved lower at like 5900 rpms f20 now make power till 8200 but fs are cheap a dime a dozen and are fun lil motors esp boosted fs they hollllddd boooost!.......................................... ................i tell u my f held its own against my 95 slc vr6 corrado i left friend drive corrado i was in cb7 dead even whole time 30 -130 was fun i also was dam shocked that that f was hangin!Last edited by speedfr3ak; 10-27-2012, 09:14 AM. Reason: f series shocked me cough nothin like a c32 tho.......Originally posted by deevergoteThis thread is over a year old, you fucking retard.
once i get the head back i will send in the engine to bisimoto . i will have him hone and build the engine , resleeve for 12.1 cr pistons . then i put it all back to gather wen it gets here . then i will put it in my 91 cb . after install then i will have it towed to him for tuning with a po6 .
thanks for the good luck.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by deevergote View PostWhy not just tell them to hold onto the head until you send the block, and have it all put together by Bisimoto at once... rather than paying for shipping multiple times (unless you're close enough to deliver everything yourself.)
I think he's like 2 hrs away? Which I would easily sacrifice the time to go up there and chat Bisi's head off in person.'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
im 3 to 4 hours away . besides i would like to get in a little wrench time . like putting the head on the block . and i have to save up for the block to be done.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
