h22 skunk2 im with h23 adapter?
    I was thinking ....is it worth spending the money for a h22 skunk2 manifold and then getting the adapter kit that they sell for the h23?...... Right now im currently on iab double stacks ... and just wondering if this will be worth it?
    IMHO absolutely, theres no way the stock manifolds can outflow the S2. It's a shame this mod isn't done more often, but then again people are just being cheap. If you port it and portmatch the throttle body there are some serious gains to be had over the H23 IM. Maybe you can popularize it in the community. Good Luck.
    '94 JDM H22A: 178whp 146wtq
      Thanks ....now i have a reason for doing this ..... im also thinking of getting an ecu from Phearable.net
        While you should make a different thread for a different topic, phearable is a good guy. He's local to me. I'm running one of his chipped P28s right now. But don't run your car on his basemaps. The basemap is designed to get you to the shop, so you can get dynoed. I think even Vega himself says this on his site.
          O wow i didnt know that ..... will do.... thanks!
            Local to you? Haha your in jacksonville :P Im 10 minutes from his house.
            It is advised to not drive around on a basemap. However the way i look at it is, i am running an h22 with bolt ons, cant be hard to makw a good basemap for that. Ive been driving around on it for over a year now with no issues.
            1991 Accord Ex - H22A - Omnipower Coilovers - Greddy SP2
            1993 Civic Dx - D15B7 - T3/T04E - Ported head - Hole in block - May be going F swap
            My Workout Log
            Originally posted by Leung
            Well, I poked the big one in the head with the shovel while shouting at it "hey, you can't sleep here".
              not to jack this thread but what about the Euro-R manifold? either way i hope this will be more popular for the guys that build a f22.
                I'm closer to him than most people on this board. I realize there may be people who are closer.
                I resent that remark about it not being too hard to make a basemap however, if that were the case you'd be making your own wouldn't you? I admit John is very damn good at what he does, and over time he probably has pretty "Safe" calibrations. But still, a basemap is a basemap, get it on the dyno, that's what it's for. You're really holding back the performance of your car with a basemap, as I'm sure he's trying to make sure it doesn't blow up, by designing something overly aggressive.
                The EuroR would be the first choice, but try finding one. And then when you do, have the cash to get it off their hands. The last one I saw was for $600 shipped.
                Or, what I think might be the best manifold out there, but even more expensive than the EuroR, the Golden Eagle Manifold no adapter required!
                  i think the golden eagle would be a great choice but it looks over kill for a stock h23. (idk if your is built or not).so i do say the skunk2 is better off.
                    I asked this question once before and i waas told you run into cpearence issues ussing the skunk 2 manifold.
                    STANCE|WORKS
                      You run into clearance issues WITH AN H22. The F22 doesn't have the second cam so there's more room for it. With the GE Manifold you might have an issue then....
                        i remember when i was installing the h22 in my brothers accord with the skunk2 manifold and the intake temp sensor was touching one of the brake lines on the master cylinder. Also had to grind off 2 studs on the firewall so the iacv would hit it.
                          will the clearance issues still be the same for the h23 ? Isnt the h22 head bigger then the h23 doch non vtec?
                            Heads should be about the same size and even if it is smaller shouldn't be by much. But with the adapter you may run into clearance issues.
                            STANCE|WORKS
                              Clearance issues or no...it should still fit. If worst comes to worst, take the head off and attach it like that. You'd just have to inconveniently do a new headgasket and timing belt. But I doubt it will get that bad. The adapter isn't even a quarter of an inch right? I think I got a good 2 inches clearance with my H22 under the hood.
