Skunk2 Throttle Body
    does any one run one of these ? you can get a 68mm or a 70mm for 297.00. what would the gains be and would it be worth the cash ? ment to say body.
    For the same amount of money more or less you could get a bisi lvl 2 cam and gain alot more.Tb might help 5hp.
    02 Crv
      If you do it you would need to portmatch your intake manifold to the same size otherwise it'd be pointless...
        Other options
        I am not saying not to get a s2 tb, but look into other options. I have a polar bear tuning tb and think its better then the s2 tb's.
        201 Whp H22a with bolt ons, see the progress from stock f22a to now HERE
          thanks guys. i have got head work and intake porting and have not upgraded my fuel system other than a adj. fuel rail with pressure reg. on it. so what do you guys recommend ? a 68mm or a 70 with new injectors and fuel pump. i have a f20 that needs to go in but am still having fun with the f .
            pbt
            I love my 74-68mm tb from pbt.
            So that is what I would recommend.
              what do you need to upgrade your fuel system for? the rail doesnt do jack squat.
              If you dont have aftermarket camshafts, a throttle body wont do anything for you regardless how much bigger you go.
              www.850fab.com
              IG - @850Fab
              FB - @850Fabrication
                Did you have to do any other modifications to fit a 68mm throttle plate throttle body on your intake, other than porting? I always figured that 65-66mm was the max bore on a stock F22 intake before you had to block off the IACV port.
                MR Thread
                GhostAccord 2.4L Blog
                by Chappy, on Flickr
                  thanks man . i have been debating on one but, was not sure.
