"Dont Knock it Till Ya Try it"
Build Thread:
Heres my plans for my Cb...All input is welcomed if you've done a similar build feel free to chime in aswell!
Head:
Delta 272 cam
Skunk2 cam gear-Purchased
Maybe a mild P&P and a 3 angle valve grind(undecided)
Trans:
H22 or 23 auto trans
Maybe a higher stall converter around 3k-3.5(If there even out there have yet to check)
Bolt ons:
I have this basically covered atm maybe some slight changes.
BBP header-Purchased
SRI with velocity stack(track use only)
P&P IM ports to match head
Bisi IM gasket-Purchased
ECU-Purchased
Maybe a 75 wet shot kit likely a zex kit as ive had good experience with them in the past.Colder plugs ofcourse.(This is the reason i put it in N/A because this will be the last thing done if i even decide to do so before tune)
Tune:
Going to ask around at some reputable tuning shops(RLZ,DG or TDC) to see what they think is best.Have yet to do as im in no rush.This build isnt much but im no baller it will take sometime to accomplish.Very mild set up which i like an will be very reliable in the long run.
Build Thread:
Head:
Delta 272 cam
Trans:
Bolt ons:
ECU-Purchased
Tune:
