F20 pistons in a F22
    I've read somewhere on here that you can use F20B (I believe) pistons in an F22A1, is that so? I think it's the 11.1 compression piston. If this is so, what kinds of gains would I be looking at? Would it be better to match it to a Bisi stage 2 cam, cam gear, and a build on the top end?
    Members Ride Thread: LX ~ EX ~ For Sale Thread
    Sold to: accord=inspire? ~ Accord214 ~ Raf99 ~ daheavyking ~ OHOYAMA ~ JunyAccord ~ CBsevenTUNER
    Bought from: Joshy ~ TypeG ~ agol ~ 92smokeaccord ~ Extacee ~ mak ~ lindiz ~ illestatus ~ F20A CB7 ~ accord=inspire? ~ marcusv8thunder
    No it's not possible to just use the piston, you would need the rods also and I imagine the crank too, if you tried it you would get a piston through the head, or a rod through the block lol, the F20b piston is taller then a f22ax piston, if you use a 12:1 f22ax piston in an f20b it drops the compression to around 8:1
    PSN ID's:Tidashoni
    1992 Accord EX Coupe
    My FS Thread
    Not so DD 2013 Subaru Impreza WRX STI
    Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
      Then what piston would I want to use in my motor?
        if your trying to bump up your compression check out kms, I haven't really looked around for f22a pistons so I don't know who else makes some but I know kms has a set of 12:1 pistons
        PSN ID's:Tidashoni
        My FS Thread
          Ditto on KMS. Bisimoto still does custom pistons on a case by case basis I believe. Arias, I believe does as well. Contact them. I'd prefer something with OEM fitment and High Performance quality if I were you.
          '94 JDM H22A: 178whp 146wtq
            F20B rods and crank in a f22 block sleeved to 89mm would be an epic win. High rod ratio, and the bore/stroke is almost square.
              At that pt, u might as well get an H22A no?
              What about F20A pistons? Are those the same as F22A pistons?
              Originally posted by lordoja
