Oil Control Orifice
    Oil Control Orifice
    What's up dudes. I recently completed my hybrid swap (F23A1 block/F22A1 head) and I think I have a slight problem. I didn't put the oil control orifice from my F22 block into my F23A1 block. As most of you may know, the F23A1 is a vtec block which did not come with the oil control orifice because of the vtec head. Since I didn't plug this "hole" what problems will I have?
    1990 CB7 - Almost Done - Delta 272, SRI, 2.25 catback, Bisi intake manifold gasket, A6 intake double stacked, H22 plenum, AEM cam gear, F23a block, F22a head, Wiseco K20 pistons, DSM 450cc injectors
    2004 Z33 - Brembo BBK, Nismo spoiler, Nismo lip, Nismo shift knob, AEM CAI
    lots and lots of smoke lol.... did you pull the head off already?
    the sedan
    http://www.cb7tuner.com/vbb/showthread.php?t=134302
    the wagon
    http://www.cb7tuner.com/vbb/showthread.php?t=150426
    the integra
    http://www.cb7tuner.com/vbb/showthread.php?t=160603
      I was hoping to get that answer, but not from you. LOL. Nah I haven't pulled it yet. I was going thru every possibility of why my car is smoking and burning so much oil first. I eliminated the valve stem seals cuz they look fine plus the main symptom of bad stem seals is a puff of smoke at start up. My shit is constantly smoking. I think I have the answer tho. I just need to get that orifice and see if that will fix it. But the head has to come off in order for me to put it on, so I'm going to need to buy some new head studs. I hope that fixes the problem though. What I'm thinking is too much oil is getting into the block via that hole and is being burned in the combustion chamber and exiting out of the tailpipe.
        Does anybody else have any input? (Thanks Jimmy )
          So nobody knows? I'm sure that I'm not the only one that has done this swap. By searching I found at least 4 others that have done this. All I need to know is by not putting the orifice on will it result in oil burning and smokinig.
            Quality is always better than quantity. Thanks for your response. I'm going to get the oil jet from the junk yard this weekend and install it. I hope and pray it fixes the problem so I can get it tuned. (fingers crossed)
              you and me both... where do you plan on getting it tuned? i still need to get mine tuned...
              the sedan
              the wagon
              the integra
                I dunno. I was waiting for you to get yours tuned first. LOL. I was gonna take it to Charm City but I was advised not to.
                  Hit me up when this thing is running right (even untuned). I'm building a very similar motor for my 97, and am trying to figure out what kind of punch its going to have. My guess based on pretty much nothing is somewhere around 170-200hp at the crank at fairly low revs (F23 makes like 155 with a shitty head, figure intake and header and improved headflow are worth at least 10-15, and the cam is probably a 20+hp gain).
                    Its already up and running, its just smoking. It has ALOT of power around 3500rpms and up and it revs quicker and higher!! I think I can keep up with H22s (right Brian, ). Its not even tuned yet.
                    These are my mods:
                    F23A1 stock block
                    F22 ported and polished head
                    Bisimoto valve springs and retainers
                    Bisimoto intake manifold gasket
                    Delta 272 cam
                    3 angle valve job
                    H22 plenum, ported
                    Double stacked runners
                    A4 header (gonna get a better one soon)
                    Accel canister external coil
                    Catback exhaust
                    Chipped P06 (running a P12 right now tho)
                      ^^^ WON BEST NA BUILD AT OUR LAST Pa MEET!
                      happy for you friend.
                      im suppose to be gettin a delta 272 cam, i will freakin drive to you and sleep in my car in order for you to help me if i need to, ill even pack water to wash up
                        yeah im not going the them anymore heard alot of mixed things about them if your not in their in crowd they get over on you.
                        the sedan
                        the wagon
                        the integra
                          Thanks bro. LOL. I have a spare bedroom and a shower you can use.
                          That's f'd up. Are there any others in Bmore?
                            These are my mods:
                            F23A1 stock block
                            Delta 272 cam
                            3 angle valve job
                            H22 plenum, ported
                            Catback exhaust
                            Holy shit that rocks. Glad to hear it runs well, especially since that's pretty much exactly my build too (aside from the bisi valvetrain parts). I'm not doing a whole lot of porting on mine though, just cleaning up the ports a little bit and doing some gasket matching. Especially since the air will be coming into the motor with pressure.
                            Gonna be awesome coming from the broken F22B2 that I currently have (makes all 130-ish hp when cold, when it warms up and heatsoaks its down between 20-40hp).
                            My parts list (before it gets turbo):
                            -Stock F23A1 bottom end (rebuilt if the bearings/compression aren't great, otherwise run straight from the junkyard)
                            -Cleaned junkyard F22A6 head with the ports cleaned up.
                            -F22B2 valvecover
                            -Delta 272 cam
                            -H23 intake mani and TB
                            -double stacked IAB plates
                            -F22A4 header (yay for deleting my precat!)
                            -F22B2 OBD2 ECU and ignition hardware
                            -rpm switch to activate secondary runners
                            -balance shafts deleted
                            -no exhaust yet, but probably a 2.25-2.5 inch custom deal with a glasspack on the midpipe and a dynomax super turbo out back.
                            Turbo parts:
                            -DSM turbo manifold
                            -eBay 16G turbo
                            -wastegate actuator modified for opening at very low boost
                            -some form of piggyback as a temporary fuel solution
                            -390cc injectors (also temporary)
                            -probably run a FMIC, painted black to try to hide it a bit.
                            I realized I'm looking at an overall gain of like 150 at the crank, lol. She's gonna move, even with the automatic transmission.
